how to add event on point?
1358
06-15-2011 08:55 PM
mikezheng
1. I created a map and publish to the server;
2. In this map, there are total 4 layers. The first layer named "locations", its type is "Point Features";
3. In web application, i loaded this map thru:
    var myLayer = new esri.layers.ArcGISDynamicMapServiceLayer(myMapUrl, { opacity: 0.5 });
    map.addLayer(myLayer );
i want to add a "onMouseOver" event on each point within the first layer, how to do that?
derekswingley1
To get dynamic interaction with your features, you need to use either a graphics layer or a feature layer. I would go with a feature layer as it's less code for you to write. Check out the Feature Layer - Snapshot mode sample. It uses polygons but the idea would be the same for points.
mikezheng
Got it. Thank you very much.
derekswingley1
You're welcome!
