Insert (add) fails
1003
05-25-2011 02:56 PM
WarrenMedernach
Hello all,
I have some simple point data in an ArcSDE geodatabase, I have published the data to ArcGIS Server, and I'm getting my feet wet with the JavaScript API.
Using the samples provided, and substituting my FeatureServers, I can get updates and deletes to work fine, but adds (inserts) do not work.
The response to the applyEdits on an insert is:
{"addResults":[{"objectId":-1,"globalId" : null,"success":false,"error":{"code":-2147216100,"description":"Error while inserting populated row into Insert Cursor"}}],"updateResults":[],"deleteResults":[]}
Any suggestions would be greatly appreciated.
Warren M
derekswingley1
I think that error normally corresponds to permissions issues...which is strange since you can update and delete without issue. Can you double-check that you have full permissions granted on your feature class?
WarrenMedernach
Hi Derek,
That's what I suspected as well, but the ArcGISSOC user has db_datareader and db_datawriter permissions and db_datawriter is supposed to have DELETE, INSERT and UPDATE permissions?
But alas, this seems to not be the case, at least as far as ArcGIS Server is concerned...  If I give the AcrGISSOC user db_owner permission, the inserts work fine.
So...  that confirms it is a permission issue, but now I need to figure out how to do this without giving db_owner permissions...
Thanks for your help.
Warren M
derekswingley1
Assigning permissions via roles might be a bit of overkill in this situation...what about assigning permissions directly on the feature class?
AndyStewart1
I am getting the same error but it doesn't happen every time. It also only happens when I am saving a drawn polygon and not a point or line. I can't find a consistent action that triggers it either. Could this still be a permissions thing?
