Dynamically create layer list
5163
05-18-2011 10:24 AM
MeghanRyan
I am new to JavaScript.  I am using the provided Base Map: AzureTwitter.  I would like to add in the code for dynamically creating the layer lists.  I found the thread link below with the coding to add in.  However I am not sure how to incorporate this code into my existing index.html and layout.js, as the code in the link below is all shown in one file.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/map_dynamiclay...
My questions:
How do I add the code.
Where do I put in the link to my dynamic layer list
Below is the  layer code.. I know I change the address.. but do I put in my unique ArcGIS Map ID in that line or a http address that is provided to me in my map settings.
        layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
Is there additional code I need to add to my javascript layout to call the layers into my index file?
Thank you for your help.  I have no prior experience with Java.. only using CSS coding, html, and ArcView Software, but no online experience.  I want to learn though.
Any recommendations for passing the learning curve?  I went through the readme.html but it helped only a little bit.
Meghan
KellyHutchins
Esri Notable Contributor
Here's an example of how you can dynamically generate a layer list using the twitter template from ArcGIS.com.
Download the attached js file and place it in the javascript folder of your application. Note: this is the location where the layout.js file is located.
Next, open the layout.js file in a text editor and add the following script tag directly below the line that adds the layout.js file (approx line 21):
 <script type="text/javascript" src="javascript/layerVis.js"></script>
Next search the layout.js file and find the section of code that checks if the map is loaded and calls the initUI function and replace it with this:
     if(map.loaded){
        initUI(itemInfo);
      else{
        dojo.connect(map,"onLoad",function(){
          initUI(itemInfo);
Finally, update the initUI function in layout.js to read as follows:
  function initUI(itemInfo) {
      //add theme for popup
      dojo.addClass(map.infoWindow.domNode, "chrome");
      var scalebar = new esri.dijit.Scalebar({
        map: map,
        scalebarUnit: "english" //metric or english
      displayLayerList(itemInfo);
RobertKirkwood
Here is some code to create the checkbox list. However, when i pan the map the check boxes in the list become unchecked. Is there a way to stop this from happening?
function buildLayerList() {
    require(["dojo/on", "dojo/dom", "dojo/_base/array"], function (on, dom, arrayUtils) {
        var mapLayer = map.layerIds;
        var myItems = [];
        arrayUtils.map(mapLayer, function (layerName) {
            var myLayer = map.getLayer(layerName);
            if (myLayer.id !== "NAIP2012" && myLayer.id !== "NAIP2009" ) {
                if (myLayer.visibleLayers) {
                    //console.log(myLayer.id + " : " + "has vis Layers");
                    var items = arrayUtils.map(myLayer.layerInfos, function (info, index) {
                        if (info.name === "Label  SEO wells by depth" || info.name === "Label  SEO wells by actual yield" || info.name === "Label  SEO wells by MWBZ top") {
                            // console.log(info.name);
                        } else {
                            if (myLayer.visibleLayers.indexOf(info.id) > -1) {
                                return "<input type='checkbox' class='list_item'" + (info.defaultVisibility ? "checked=checked" : "") + "' id='" + info.name + "CB'' /><label for='" + info.id + "'>"
                                        + info.name + "</label><br>";
                    myItems = myItems.concat(items);
        var ll = dom.byId("legendDiv");
        ll.innerHTML = myItems.join(' ');
        document.getElementById("legendDiv").style.display = "block";
I am calling on the buildLayerListin the map:
mapLayer.on('update-end', buildLayerList);
