Feature Layer Selection
4231
05-11-2011 02:22 PM
JaclynGorman
For the following example:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/fl/fl_selectfeatures.html
how do you set up a graphic selector similar to this example:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/graphics/graphics_add.html
Basically, I want the person to be able to choose what color appears when they select the feature layer.  The selection can't be based on an attribute since color selection will be determined by the person using the map and can change next time they use the map.  There will be a choice of 3 colors. I've tried a few things but can't get it to work. Thanks
Jaclyn
derekswingley1
How about this:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
  <meta http-equiv="X-UA-Compatible" content="IE=7" />
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>change feature layer selection color on the fly</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.2/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript">djConfig = { parseOnLoad:true };</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script>
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      var selectionToolbar, featureLayer;
      var syms = {}
      function init() {
        // populate the object used to set the
        // feature layer selection symbol
        syms.red = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255,0,0,0.5]));
        syms.blue = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0,0,255,0.5]));
        syms.green = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0,255,0,0.5]));
        var initialExtent = new esri.geometry.Extent(-97.5328,37.4344,-97.2582,37.64041, new esri.SpatialReference({wkid:4326}) );
        var map = new esri.Map("map", { extent: esri.geometry.geographicToWebMercator(initialExtent), slider: true, nav: true });
        dojo.connect(map, "onLoad", initSelectToolbar);
        var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
        map.addLayer(baseMapLayer);
        var content = "<b>Status</b>: ${STATUS}" +
                      "<br><b>Cummulative Gas</b>: ${CUMM_GAS} MCF" +
                      "<br><b>Total Acres</b>: ${APPROXACRE}" +
                      "<br><b>Avg. Field Depth</b>: ${AVG_DEPTH} meters";
        var infoTemplate = new esri.InfoTemplate("${FIELD_NAME}", content);
        featureLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/1",{
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          infoTemplate: infoTemplate,
          outFields: ["*"]
        featureLayer.setDefinitionExpression("PROD_GAS='Yes'");
        featureLayer.setSelectionSymbol(syms[dojo.byId('color-select').value]);
        dojo.connect(featureLayer, "onSelectionComplete", sumGasProduction);
        dojo.connect(featureLayer, "onSelectionClear", function(features) {
          dojo.byId('messages').innerHTML = "<i>No Selected Fields</i>";
        // connect to the drop-down's onchange event and
        // change the feature layer's selection color
        dojo.connect(dojo.byId('color-select'), 'onchange', function(evt) {
          featureLayer.clearSelection();
          featureLayer.setSelectionSymbol(syms[evt.target.value]);
        map.addLayer(featureLayer);
      function initSelectToolbar(map) {
        selectionToolbar = new esri.toolbars.Draw(map);
        var selectQuery = new esri.tasks.Query();
        dojo.connect(selectionToolbar, "onDrawEnd", function(geometry) {
          selectionToolbar.deactivate();
          selectQuery.geometry = geometry;
          featureLayer.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_NEW);
      function sumGasProduction(features) {
        var productionSum = 0;
        //summarize the cummulative gas production to display
        dojo.forEach(features, function(feature) {
          productionSum = productionSum + feature.attributes.CUMM_GAS;
        dojo.byId('messages').innerHTML = "<b>Selected Fields Production: " + productionSum + " mcf. </b>";
    dojo.addOnLoad(init);
  </script>
</head>
<body class="claro">
  <button dojoType="dijit.form.Button" onClick="selectionToolbar.activate(esri.toolbars.Draw.EXTENT);">Select Fields</button>
  <button dojoType="dijit.form.Button" onClick="featureLayer.clearSelection();">Clear Selection</button><br>
  <select id="color-select">
    <option>red</option>
    <option>blue</option>
    <option>green</option>
  </select>
  <div id="map" style="position: relative; width:700px; height:500px; border:1px solid #000;"></div>
  <span id="messages"></span>
</body>
</html>
Also try it on JS Fiddle:  http://jsfiddle.net/swingley/HeJux/
JaclynGorman
Thank you.  With a few changes this worked perfectly.
JaclynGorman
Can someone help me determine why the following code won't work in IE. It works fine in Firefox.
<html>
<head>
  on iOS devices-->
      var syms = {}
   var selectionToolbar2, featureLayer2;
      var syms2 = {}
      function init() {
  syms2.red = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255,0,0,0.5]));
        syms2.blue = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([0,0,255,0.5]));
        syms2.green = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([0,255,0,0.5]));
  dojo.connect(map, "onLoad", initSelectToolbar2);
          outFields: ["*"]
  featureLayer2 = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0",{
        featureLayer2.setDefinitionExpression("FIELD_NAME is not null");
        featureLayer2.setSelectionSymbol(syms2[dojo.byId('color-select2').value]);
        dojo.connect(featureLayer2, "onSelectionClear", function(features) {
        dojo.connect(dojo.byId('color-select2'), 'onchange', function(evt) {
          featureLayer2.setSelectionSymbol(syms2[evt.target.value]);
        map.addLayer(featureLayer2);
          featureLayer.selectFeatures(selectQuery, esri.layers.FeatureLayer.SELECTION_ADD);
    function initSelectToolbar2(map) {
        selectionToolbar2 = new esri.toolbars.Draw(map);
        var selectQuery2 = new esri.tasks.Query();
        dojo.connect(selectionToolbar2, "onDrawEnd", function(geometry) {
          selectionToolbar2.deactivate();
          selectQuery2.geometry = geometry;
          featureLayer2.selectFeatures(selectQuery2, esri.layers.FeatureLayer.SELECTION_ADD);
  </script>
</head>
  </select>
  <select id="color-select2">
  </select>
  <button dojoType="dijit.form.Button" onClick="selectionToolbar2.activate(esri.toolbars.Draw.EXTENT);">Select Fields</button>
  <button dojoType="dijit.form.Button" onClick="featureLayer2.clearSelection();">Clear Selection</button>
</body>
</html>
The selection is working but it isn't adding color.
Jaclyn
