Android: Click on Graphic Problem
1130
05-10-2011 02:57 PM
Gregme
Hi:
I'm having problems with a mobile JavaScript based site I am building when trying to get the click event on a graphic to fire. The same problem occurs on one of the samples:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_infowindow.html
What happens on my site, like this site, is that only rarely when I click on one of the graphics on the map does the click event fire. Just like the sample, this does not occur in Desktop Chrome browser, IR or on the iPhone.
Any suggestions?
Greg
KellyHutchins
Esri Notable Contributor
For Android, you many need to increase the click tolerance. The default value that we use is 5 pixels. You can increase this using the following after the page loads:
esri.layers._GraphicsContainer.prototype._tolerance = 15;
Gregme
That worked! Thanks so much!
