GeoTagged Image attachment to the service
555
10-15-2020 08:57 AM
SrinivasaRao1
We are developing a widget where we can get lat/lan values from geotagged photos and then it will copy the lat/lan values to the published service so here our query is that we can add 1 image at a time but if we have multiple images than images are not attaching for all the lat/lan values generated, all images added to one feature, ideally this is not correct, is there any process to overcome. we can see there is a facility in ArcGIS online for these geotagged images but clients require a through the widget.
Regards,
Srinivas
ErwinSoekianto
Esri Alum
Srinivasa,
Can you give us a little more context about what you are trying to build as far as the product? Are you using AppStudio? Are you using one of our templates or custom app? You mentioned "widget", we don't have a concept of widgets in AppStudio.
In AppStudio AppFramework, we have ExifInfo https://developers.arcgis.com/appstudio/api-reference/qml-arcgis-appframework-exifinfo/ where you can set or get property from images including location data.
Thank you,
Erwin
SrinivasaRao1
Thanks for reply.
We are building widget in webappbuilder.
Is there any way to get Lat/Lan values to the published services through code for multiple images when selected.
Hope I have provided information,
ErwinSoekianto
Esri Alum
I am going to tag ArcGIS Web AppBuilder‌ as that is the correct group.
