Calculated If statement
1022
10-12-2020 02:42 PM
JordanMiller4
How do you write an If statement based on a value from previous fields. If TYPECODE = 3 and MCF is > 500 calculate 1801 Engineering Dept as the answer? My statement below doesn't seem to work. Any help would be appreciated!
${TYPECODE}='3' and if(${A00MCFTOTAL}>500,"1801 Engineering Dept"))
Jim-Moore
Hi Jordan
Your expression is almost there; try putting the and argument inside the if() statement. Also, if() statements require three arguments: a condition; the result if the condition is true; and the result if the condition is false, i.e.
if(condition, value if true, value if false)
So your expression could look something like:
if(${TYPECODE}='3' and ${A00MCFTOTAL}>500,'1801 Engineering Dept','Some other value')
Replace 'Some other value' with the desired output if false (use '' for a blank).
Please find more on formulas here Formulas—ArcGIS Survey123 | Documentation
Best,
Jim
Jim-Moore
Hi Jordan
Best,
Jim
JordanMiller4
Thank you! this is perfect!
