survey123 for EMUI 9 /10
869
10-04-2020 07:14 PM
Arturo_FranciscoAcosta_Bazán
Hola, para los dispositivos (HUAWEY) que tienen el SO EMUI como se puede obtener el   apk para que pueda instalarse en estos móviles ?.
En la página de recursos aparecen listadas estas opciones
En  qué casos se utilizan   ?
Gracias
BrettStokes
Hello Arturo,
Appologies in advance, I'm using Google translate for your question.
Which Huawei device are you using? Most newer devices will be ARM V8 (64-bit). The EMUI OS is supported on ARM V7 (32-bit), x86 (32-bit) and ARM V8 (64-bit) so I'm not sure which option you need. Please select the appropriate download from the Survey123 Resources page depending on your specific Huawei device.
The download itself will be a .exe file. You will need to run this on a Windows machine, it will prompt you to accept the license agreement and then ask you for a location to extract the .apk file. This .apk file can then be sideloaded to your device and installed as normal.
Hope this helps,
Brett
