Error 002667 Unable to initialize python raster function with scalar arguments
6937
10-03-2020 09:21 AM
Krishna_KumarVSAV
Hi All,
When using Detect Objects Using Deep Learning, I'm getting below error. I created this model using RetinaNet. Any Ideas on how to solve this?
I have installed DeepLearning Libraries as given at below link:
deep-learning-frameworks/README.md at master · Esri/deep-learning-frameworks · GitHub
Appreciate your suggestions on this.
Krish
DanPatterson
MVP Esteemed Contributor
Deep Learning Object Detection:ERROR 002667 Unable to initialize python raster function with scalar... Deep Learning Object Detection Error: Unable to initialize python raster function with scalar argume...
Only 2 threads on GeoNet and no bugs reported on the Tech Support site, but many people suggest wrong graphics card, wrong version of Tensorflow or some combination of those.
Also
is supposed to be the version for Arcgis pro 2.6
If none of that helps, then you should report to Technical Support
... sort of retired...
by Anonymous User
Not applicable
I had the same error 002667, I solved it by manually installing the libraries that my argis pro version requires.
this document helped me:
