ArcGIS Notebook permissions error
1050
08-27-2020 07:28 AM
JoeBorgione
I'm experimenting with a simple notebook in my AGOL account, following this post How to download feature layer(s) to local machine using notebook as a template.
Here is the code. Each block is a notebook cell:
from arcgis.gis import GIS
gis = GIS('home')
item_id = '4f9d1d1301864f8cabef08cbae7b2d3c'
item = gis.content.get(item_id)
item_gdb = item.export(item.title + '_test', 'File Geodatabase')
It errors out at line 7 with:
Exception: You do not have permissions to access this resource or perform this operation.
(Error Code: 403)
What is odd about this is I can manually export the item from the item's details page without a problem, and the exported shapefile or gdb shows up in my root contents directory.  I must be missing a simple step, but I don't know what it is.
Tags (1)
DanPatterson
MVP Esteemed Contributor
arcgis.gis module — arcgis 1.8.2 documentation
Exports a service item to the specified export format. Available only to users with an organizational subscription. Invokable only by the service item owner or an administrator. This is useful for long running exports that could hold up a script.
The help is short on anything useful re examples.
... sort of retired...
JoeBorgione
There does seem to be a lacking of practical examples.  It's just weird that I can manually do it, but the api errors out.  Hard saying where the disconnect is.
