Querying history with output to Dataframe
1056
08-25-2020 10:31 AM
DanielLaSusa
Environment:
Windows 10
Python 3.8.5
ArcGIS for Python 1.8.2
Querying ArcGIS Online
The following code works, output as csv, then read that csv back in as a Dataframe:
x = gis.admin.history(start_date=start_date, to_date=end_date, num=100, data_format='csv')
df = pd.read_csv(x)
Leaving everything the same, but trying to output directly as a Dataframe:
df = gis.admin.history(start_date=start_date, to_date=end_date, num=100, data_format='df')
Produces a TypeError :
TypeError: list indices must be integers or slices, not str‍
Full Traceback:
TypeError                                 Traceback (most recent call last)
<ipython-input-69-d921e39fa9da> in <module>
----> 1 df = gis.admin.history(start_date=start_date, to_date=end_date, num=-1, data_format='df')
      2 # df = pd.read_csv(x)
~\Anaconda3\lib\site-packages\arcgis\gis\admin\agoladmin.py in history(self, start_date, to_date, num, all_events, event_ids, event_types, actors, owners, actions, ips, sort_order, data_format, save_folder)
    338
    339             res = self._gis._con.post(url, params)
--> 340             data.extend(data['items'])
    341             while len(res['items']) > 0 and res['nextKey']:
    342                 params['start'] = res['nextKey']
The data variable is a list, so I don’t think we can do this: data['items']
I THINK it’s meant to be: data.extend(res['items']) on line 340 where res is the response from the post  (line 339)
Similarly, on line 345 I changed:
data.extend(data['items'])  -->  data.extend(res['items'])
Everything seems to be working, but wasn’t sure if my “fix” might break something else?  So I was hoping to get some feedback or an “all clear” message that this fix "works" and won't break other things.  Thanks!
DanielLaSusa
One quick follow up.  This is the change in code I made that seems to work.  My version on the left (red highlight) and the original version on the right (green highlight).
updated agoladmin.py  vs.  original agoladmin.py
*This is in the agoladmin.py file*
