Image-map - Pre-Select Choice using previous field
1116
08-18-2020 10:21 AM
EdgarSerio
hi! i wonder if its possible to pre-select a Choise-One in a image-map using the calculate condition:
in my example its like this:
i whant to put any value... for example "20" in a integer field and after that i what to automatically be selected at the image-map choise:
i can bring the value... but when i made it using the iamge-map it seems to be not working well... here is the result:
and here its what it want to achive:
here its the code that im writeing in the Calculate field at the image-map choise: if((${h_cosecha} = 20   ) ,'20-1-23',0)
'20-1-23' its the awnser wanted at the choice sheet
i hope i made mysef clear... any questions im here
Federico
Jim-Moore
Hi Federico
The logic you're using should work; just to double-check, is "20-1-23" the name of the choice on the choices sheet, or the label? For the calculation to work it must be referencing the name of the choice, not the label.
Best,
Jim
