Hidden appearance for geopoint
2130
08-06-2020 05:15 PM
AndrewPadilla
Is "hidden" appearance be supposed to be available in  Connect 3.10? I downloaded and installed 3.10 and created a new form but hidden does not seem to be an option under appearance. When typing in "hidden" under appearance I get a popup "The appearance value you gave is not one of the standard supported appearance types..." My goal is to hide a geopoint. I am running Windows 10. Will this option also be available for the web app?
Also I do not see the "body::esri:visible" column as shown during the UC "ArcGIS Survey123: What's New" presentation.
Thank you,
Andy
by Anonymous User
Not applicable
Hi Andrew,
The hidden appearance and body::esri:visible column are beta features for the 3.10 release. Both of these new features currently work as expected in Connect and the field app with 3.10, however are not supported in the 3.10 web app. Once they are supported in the web app (currently scheduled for 3.11) then both features will be fully supported.
The templates therefore do not contain the hidden appearance and body::esri:visible column, however you can manually add it to your template, and use in Connect and field app.
Regards,
Phil.
AndrewPadilla
Thank you for your response Phillip. To make sure I understand correctly, in 3.10, I can add hidden to appearance (bypassing the popup message as stated above) and it should work in Connect and the field app?
Andy
by Anonymous User
Not applicable
Yes, that is correct, it will work as a beta feature (not officially supported) in Connect and field app with 3.10 release.
Regards,
Phil.
