arcpro 2.6 arcpy fgdb lock files not clearing
7289
11
08-03-2020 12:53 PM
KennethSmith1
I recently upgraded to Arcpro 2.6 and am having issues with an ArcPy script that exported data to a file geodatabase and then zipped that fgdb.
res=arcpy.FeatureClassToFeatureClass_conversion(in_features=inFeature, out_path=I10_fgdb, out_name=FC)
del res
 shutil.make_archive(fgdbPath, 'zip', ZipPath,fgdb)
This worked just fine in 2.5.X, however, after the upgrade, the lock file in the FGDB directory is not going away and that causes the zip to fail. How can I get ArcPy to clear the lockfile in a FGDB?
DanPatterson
MVP Esteemed Contributor
If this worked in 2.5, I would report to Technical Support.
Arcpy can't clear locks... it is well requested item
... sort of retired...
CooperLogan
Hi Kenneth Smith
It sounds like this issue has been reported as a bug with 2.6:
[ BUG-000133976: Unexpected behavior creating file geodatabases at 2.6 ]
Hope this helps!
Cooper
DonMorrison1
Hi Cooper - do you know if there is a way to circumvent this problem?  I have a number of critical scripts that are broken due this bug.  I'm willing to go in and add some code if necessary.  It looks to me like the only way to get rid of that lock file is to end the python script's process, but to do that in the middle of the script is really not feasible.
DanPatterson
BUG-000133976: Unexpected behavior occurs when creating file geodat..
no alternate solution provided
CooperLogan
Hi Don,
One workaround that allowed some users to circumvent the problem is to add the following line right before the script errors out:
  • arcpy.ClearWorkspaceCache_management()
I hope this helps!
Cooper
Don Morrison
MarcoBoeringa
Cooper Logan‌,
I am confused. This issue is about File Geodatabases being kept locked. The workaround you suggested shouldn't work according to this Help page, as arcpy.ClearWorkspaceCache_management() is only supposed to do anything for Enterprise Geodatabases, not File Geodatabases. The Help is quite adamant on that aspect:
"This tool only works with enterprise geodatabase workspaces."
JustinKraemer
@MarcoBoeringa, I saw your reply, but decided to give it a try anyway, and found it worked! Mine is a file geodatabase. Just thought I should share
GavinMcGhie
I would add that I also used this solution to resolve a lock on an FGDB prior to trying to zip it with py.shutil and it resolved my issue as well even through it's an FGDB!
MarcoBoeringa
I also wonder if this issue is actually being worked on? This is a quite hideous issue, causing significant problems for arcpy / Python development. I have reported a similar issue to the Dutch branch of ESRI based on a custom arcpy Python geoprocessing tool of mine that suddenly started failing going from Pro 2.4.3 to Pro 2.5, and the issue was also caused by left over *.lock files in a File Geodatabase folder, that weren't being cleaned up in Pro 2.5, while not an issue and being cleared properly in Pro 2.4.3.
It is registered as:
BUG-000131154 Fgdb locking behavior is different in ArcGIS Pro 2.5 to ArcGIS Pro 2.4.3 for copying styles
