Create polygon through JSON with proper symbol
1752
07-29-2020 11:42 PM
rsharma
Hi i m naive to arcgis appstudio and trying to create multiple polygons through JSON set of vertices, i have my vetices in json format in db like below, but my geometry symbol do not support it.
Kindly guide in right direction.
Or my question could be like.. how to create a polygon through JSON data
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import QtQuick.XmlListModel 2.0
import ArcGIS.AppFramework 1.0
import Esri.ArcGISRuntime 100.2
Item {
    //! [GOSymbols MapView]
    // Map view UI presentation at top
    MapView {
        anchors.fill: parent
        rotationByPinchingEnabled: true
        zoomByPinchingEnabled: true
        Map {
            BasemapOceans {}
            initialViewpoint: viewPoint
        GraphicsOverlay {
    // the center of the mapview
    ViewpointCenter {
        center: Point {
            x: 172.49307355493
            y: -43.4810759934974
            spatialReference: SpatialReference {
                wkid: 4326
        targetScale: 288895.277144
    //! [GOSymbol line symbol]
    SimpleFillSymbol {
        style: Enums.SimpleFillSymbolStyleSolid
        color: Qt.rgba(1, 1, 0, 0.4)
        SimpleLineSymbol {
            style: Enums.SimpleLineSymbolStyleSolid
            color: "blue"
            width: 2.0
             antiAlias: true
    // add all the graphics to the graphics overlay
    Component.onCompleted: {
      // add boat route
        graphicsOverlay.graphics.append(createGraphic(createBoundaryRoute(), fillSymbol));
        // add the nesting ground
    //! [GOSymbol createGraphic]
    // create and return a graphic
    function createGraphic(geometry, symbol) {
        var graphic = ArcGISRuntimeEnvironment.createObject("Graphic");
        graphic.geometry = geometry;
        graphic.symbol = symbol;
        return graphic;
    //! [GOSymbol createBoatRoute]
    // create the boat route
    function createBoundaryRoute() {
        // create polygine using json
        return ArcGISRuntimeEnvironment.createObject("Polygon", {"json": boundaryJson});
    //! [GOSymbol boatRouteJson]
    property var boundaryJson : {"paths":[[[172.49307355493, -43.4810759934974],
                                            [172.5030454523, -43.4334343434],
                                            [172.481307356908, -43.391075445974],
                                            [172.47307356908, -43.419075445974],[172.49307355493, -43.4810759934974]]],
                                  "spatialReference":{"wkid":4326}}
LucasDanzinger
Esri Frequent Contributor
Everything in ArcGIS Runtime that can go to/from JSON is based on the ArcGIS REST spec.
So for geometries, you can reference this doc - Geometry objects—Common Data Types | ArcGIS for Developers
For symbols, Symbol Objects—Common Data Types | ArcGIS for Developers
ErwinSoekianto
Esri Alum
I am going to tag ArcGIS Runtime SDK for Qt‌ to see if anyone in that group knows the json format to create Polygon.
I think this must be related to how the json is supposed to be formatted.
LucasDanzinger
rsharma
Thanks i was using paths in attributes instead of rings
