Can I add fields to a Survey123 form without losing data?
1448
07-29-2020 08:21 AM
JamesKelly4
Can I add fields to a form without losing data already in the feature service? Or do I need to publish it as a new survey and start over to make sure no data is lost? My understanding as of a couple years ago is that the latter was true, but I wanted to check to make sure that is still the case. Please advise. Thanks in advance! James Tedrick
JamesTedrick
Esri Esteemed Contributor
Hi James,
As Publish your survey—Survey123 for ArcGIS | Documentation indicates, you can add fields without requiring the creation of a new feature service.
JamesKelly4
Thanks, James Tedrick‌! And I don't need to be concerned about losing data? I'll read the post too. Thanks again!
