ArcGIS Monitor - Collector Connection Error
1536
07-25-2020 01:20 AM
FraserHand
I've had one of these pop up on one of my collectors:
restarting the service doesn't seem to help - nor does recreating the service.
I can import the collector and start again but am wondering what the root cause is and if there is a work around.
ArcGIS Monitor 10.6.1
Fraser
Andrew SakowiczFrank PizziEvan MosbyAaron Lopez
FrankPizzi
Fraser,
The ArcGIS Administrator is composed of 2 parts. The graphical user interface and the services that the user creates. When a user creates a service in ArcGIS Administrator, the service is composed of the test interface for the service and the collector for the service. The service test interface is associated with the required port when the user defines the service. The test interface is used by ArcGIS Administrator to validate each configured item before adding the new item to a list of validated definitions. Once an item is validated, the service will observe the target and send the results to ArcGIS Monitor Server. When the user clicks test on an item the GUI calls localhost:port. If the machine cannot resolve localhost or the port is not available on the machine the connection error is reported.
Feel free to send me an email and I can guide you to review the service test logs.
SineKelly17
Hi Frank,
I am having a similar issue and am unsure how to resolve. How can I review the service test logs?
Síne
