Query for Related table in Inbox Query
1304
07-23-2020 11:01 AM
BenBond
I am working on a Survey123 app that utilizes the inbox for lechate monitoring at a landfill.  I would like to use the inbox to create a list of all the wells they have to measure for each day.
I currently have the query set to [Status='Active'] and that will pull in all the wells that need to be measured.  I then use a related table in a repeat for them to store the measurements.
The only problem is once they refresh the form all the wells will reappear.  So is there any way to add a related table query to the inbox query to only show wells that are [Status='Active'] and do not have a related table measurement taken today.
I hope that is as clear as mud...
Thank you
ZacharySutherby
Hello Ben Bond‌,
One option would be to add a calculation question in your repeat and in either the Calculation or Default columns put a value of 1.
Outside of the repeat you can create a hidden question and have a calculation that counts the number of those calculate questions. The calculation would look like count(${repeat_calculation}).
You can then modify your where clause to be Status='Active' AND repeatcount>'1'.
My sample XLSForm looked like:
begin repeat
text (for testing)
calculate                         Calculation: 1
end repeat
hidden                         Calculation: count(${calculate})
Thank you,
Zach
Thank you,
Zach
ZacharySutherby
Hello Ben Bond‌,
begin repeat
text (for testing)
end repeat
Thank you,
Zach
Thank you,
Zach
BenBond
Zach,
Ooo, I like that.  Initially as I was posting this question I though the easiest work around would be to create a new field on the base Lechate table and modify it with the last date pumped.  But I didn't really want to manage constant updates to the base table and have a field dedicated solely to the last time it was updated.
I really like the idea of performing the calculation in the repeat and filtering by a hidden field.  Sound great, I'll give it a try.
Thank you!
-Ben
