Strange errors in Pro's Python window with search cursor
3061
11
07-17-2020 03:30 PM
DanDeegan
address_sum = 0
with arcpy.da.SearchCursor('AddressPtsFormatted' ["PLOC_"]) as cursor:
   for r in cursor:
   number = r[0]
   address_sum += number‍‍‍‍
returns the error:
Traceback (most recent call last):File "<string>", line 1, in <module> TypeError: string indices must be integers‍‍‍‍‍‍‍
The code runs in jupytr notebook
(no, i wasn't adding up every address in my area because I am loopy on Friday afternoon, why would anyone find the sum of addresses)
JoshuaBixby
MVP Esteemed Contributor
At a minimum, you are missing a comma after the first argument in your SearchCursor.  Try fixing that first.
JoshuaBixby
It looks like you posted a partial Traceback, can you share the whole thing?  Does Line 1 in your code snippet line up with Line 1 in the error message?  I am guessing not because setting a variable to zero would not generate a TypeError.
DanDeegan
That was what was in the Python window in Pro.
Normally when I used cursors, row[0] is not an issue
and it works in this:
PLOCU_set= set(r[0].replace(" ", "") for r in arcpy.da.SearchCursor(fc, ["PLOCU_"]) if not r[0] is None)
DanPatterson
also, lines 4 and 5 are not indented properly
... sort of retired...
DanDeegan
I tried to make it look better from what was pasted in from Pro. The code runs fine in a jupytr notebook.
DanDeegan
fc = "AddressPtsFormatted"
address_sum = 0
   for r in cursor:
       number = r[0]
  File "<string>", line 3, in <module>
TypeError: string indices must be integers‍‍‍‍‍‍‍‍‍
This is what I ran. I cant edit the first post. And I just learned that it helps to set the language before you past code
JoshuaBixby
DanDeegan
ohhhhhhhhhhhh thats it i bet
curtvprice
Look for the edit button at upper right (you can't edit in a dropdown but you can edit by clicking up there).
Not that it matters that much: new Geonet platform soon!
DanDeegan
Side by Side comparison of jupytr notebook and Pro
