Strange errors in Pro's Python window with search cursor
3214
11
07-17-2020 03:30 PM
DanDeegan
address_sum = 0
with arcpy.da.SearchCursor('AddressPtsFormatted' ["PLOC_"]) as cursor:
   for r in cursor:
   number = r[0]
   address_sum += number‍‍‍‍
returns the error:
Traceback (most recent call last):File "<string>", line 1, in <module> TypeError: string indices must be integers‍‍‍‍‍‍‍
The code runs in jupytr notebook
(no, i wasn't adding up every address in my area because I am loopy on Friday afternoon, why would anyone find the sum of addresses)
by Anonymous User
Not applicable
You might check the value type which script returns, it looks like the type is string rather than integer.
jefryarch
TypeError: means that you are trying to perform an operation on a value whose type is not compatible with that operation. An Iterable is a collection of elements that can be accessed sequentially . In Python, iterable objects are indexed using numbers . When you try to access an iterable object using a string or a float as the index, an error will be returned as TypeError: string indices must be integers. This means that when you're accessing an iterable object like a string or float value, you must do it using an integer value.
