Survey repeat value not saving in Drafts
724
07-16-2020 12:55 PM
MichaelBlair
We're running into an issue where the values entered into a repeat don't save in the additional repeat entry when the survey is saved in a draft.  The first value is saved when brought out of draft.
Shwu-jingJeng
Hi Michael,
Could you provide more information with this issue? What version of the field app are you using? What device or OS platform are you running the field app? Do you have any calculation set with your repeat? Is it possible to share the XLSForm with us?
