Number format in colorizer
2342
7
07-16-2020 08:41 PM
by Anonymous User
Not applicable
Hi Guys,
Would like to check how to set number format in CIMRasterClassifyColorizer object.
Below is the code I am using and it does not seem to be working. Uma Harano‌?
  CIMRasterClassifyColorizer newColorizer = await this.SelectedRasterLayer.CreateColorizerAsync(classifyColorizerDef) as CIMRasterClassifyColorizer;
            var numberFormat = new CIMNumericFormat();
            numberFormat.RoundingOption = esriRoundingOptionEnum.esriRoundNumberOfDecimals;
            numberFormat.RoundingValue = this.DecimalPlaces; //int 1 or above
            newColorizer.NumberFormat = numberFormat;
this.SelectedRasterLayer.SetColorizer(newColorizer);
When I check in Advance symbol option, it seems to be effective. but the labelling does not follow at all.
ArcGIS pro version I am using is 2.5.0.
by Anonymous User
Not applicable
Hi Uma Harano‌,
Found out how to use NumberFormat class.
I have to instantiate first and Here is my complete code working in 2.5
                RoundingOption = esriRoundingOptionEnum.esriRoundNumberOfDecimals,
                RoundingValue = this.DecimalPlaces,//int 1 or above
                ZeroPad = true
            ArcGIS.Desktop.Internal.Core.NumberFormat<CIMNumberFormat> NumberFormat = new ArcGIS.Desktop.Internal.Core.NumberFormat<CIMNumberFormat>(numberFormat);
            foreach (var br in newColorizer.ClassBreaks)
                var specialChar = br.Label.Substring(0, 1);
                //var value = NumberFormat.ValueToString(numberFormat, br.UpperBound);
                var value = NumberFormat.FormatNumber(br.UpperBound);
                br.Label = $"{specialChar}{value}";
by Anonymous User
Not applicable
Hi Wolfgang Kaiser‌,
Any idea on that issue? or I miss some code to notify TOC UI change?
UmaHarano
Than,
This has been fixed in 2.6 (released today).
You can do something like this in code to fix the labels in the TOC to reflect your number format.
          RoundingValue = 3,//int 1 or above
          ZeroPad = true
        rasterColorizer.NumberFormat = numberFormat;
        foreach (var br in rasterColorizer.ClassBreaks)
Uma
by Anonymous User
Not applicable
Thank Uma Harano‌,
Is your sample code based on 2.6 or 2.5?
In 2.5, I can't find NumberFormat class, may I know which library you are using?
Best Regards,
Than
by Anonymous User
Not applicable
Hi Uma Harano‌,
                ZeroPad = true
UmaHarano
Hi Than,
Pro 2.6 was released yesterday. A new NumberFormat class in the Mapping assembly has been added to help with this.
Uma
by Anonymous User
Not applicable
Thank Uma Harano‌,
So your sample code is based on 2.6.
So in this thread there are two correct answer one for 2.6, one for 2.5 how to make both correct?
Best Regards,
Than
UmaHarano
Hi Than
The code I provided is for 2.6.
In 2.5, when you make changes to the Number format of a renderer/colorizer using the API, it does not get updated in the TOC. This is a known issue in the 2.5 version of the Pro API. There is no fix for this in 2.5. I just checked out the code snippet you provided above - it is using an Internal class. It is recommended to not use Internal namespaces.
We have now fixed this in the 2.6 API using the new static class you can see in my code snippet.
Uma
