"Add Data" widget for AppStudio
1351
5
07-10-2020 02:56 PM
RyanGay1
I am new to the coding world. And when I say new I mean I am just now taking classes. However I have been in the GIS game for a number of years. I am trying to build a native application with AppStudio but I am running into a snag. My app is simple enough. I just want to display a feature service with popups, but also I need it to have the ability to add data (zipped shapefile, KML or KMZ, etc.) so the user can overlay their data on top of the background data I am providing. I can do this all day long with the web app builder, but is there a tool or widget I can customize the Map Viewer template with or possibly another route? Thank you.
ErwinSoekianto
Esri Alum
Ryan,
MapViewer template in AppStudio does not have "Add Data" functionality you described, but I know that working with KML file is supported in ArcGIS Runtime SDK for Qt‌, so this would be a customized version of the MapViewer template with functionality to select a file then use the KML file in the MapViewer template.
Thank you,
Erwin
RyanGay2
Would I incorporate the code from "Display KML" into the MapViewer template?
ErwinSoekianto
Esri Alum
The link you provided is pointing to ArcGIS Runtime SDK for .NET, we are using ArcGIS Runtime SDK for Qt. Also I think we recently add a sample called "Create, Edit and Save KML File", that is based on this sample from Runtime, Display KML | ArcGIS for Developers
RobStauder
Hi Ryan,
Not sure if it's too late on this one but here's what I did for file based datasets (kml/kmz and shapefiles):
1. Use the DocumentDialog type. It's in beta and doesn't allow you to filter by file extensions (lol) -
        FileInfo {
        DocumentDialog {
            onAccepted: {
                // add the attachment to the feature table
                fileInfo.url = filePath
                var lyr = createFromFile(fileInfo);
                mapView.map.operationalLayers.append(lyr);
    function createFromFile(file_info) {
        //read file extension - is it .shp or .kml/kmz?
        var ext = file_info.suffix
        var file_path = file_info.url
        if (ext === 'kml' || ext === 'kmz') {
            // create the dataset from a local file
            const kmlDataset = ArcGISRuntimeEnvironment.createObject("KmlDataset", {
        //url: AppFramework.userHomeFolder.fileUrl(caKmlPath + "/SubDivs.kmz")
        url: file_path
            // create the layer
            const kmlLayer = ArcGISRuntimeEnvironment.createObject("KmlLayer", {
        dataset: kmlDataset
            // return the KML Layer
            return kmlLayer;
        if (ext === 'shp') {
            const shpFeatTbl = ArcGISRuntimeEnvironment.createObject("ShapefileFeatureTable", {
        path: file_path
            const shpLyr = ArcGISRuntimeEnvironment.createObject("FeatureLayer", {
        featureTable: shpFeatTbl
            return shpLyr;
2. Enable drag and drop on the map. This was awesome!
        DropArea {
            anchors.fill: parent
            FileInfo {
            onEntered: {
                if (drag.urls.length === 1) {
                    // verify that this file exists
                    dropFileInfo.url = drag.urls[0];
                    if (dropFileInfo.exists) {
                        if (validateFileExtension()) { //just checks for kml/kmz + .shp
                            drag.accept();
                        else {
                            console.log("Not KML/KMZ or Shp");
            onDropped: {
                    var droplyr = createFromFile(dropFileInfo);
                    mapView.map.operationalLayers.append(droplyr);
Best of luck w/your work!
Rob
RyanGay2
Rob thank you so much for sharing this. I have not had the time to dedicate to it lately. Please excuse my ignorance as I am still pretty new and still learning, but where would I incorporate this code?
