Short answer is no if it is just text. But I came up with a kind of way using a Defaults page.
See here https://community.esri.com/thread/205999-is-it-possible-to-auto-populate-previous-data-into-current-...
If it is numbers in order like last mileage then you can use max() to get the last highest value.
In yours maybe you could move PRV outside the repeat? Not sure if there are multiple. If there is then you could add PRV default like I did above.
If they are set size codes then you could use join combined with substring to pick off the last value. Not sure what you data looks like. Can it be a drop down box?
Hope one of those ideas help.
