ArcGIS Public - Basemap localization
2944
07-01-2020 04:39 AM
AnandPaleja
I have created a Web application using ArcGIS JS API 4.15. where I am using BaseMap Gallery with default Basemaps coming from portal.
I know using dojoConfig, I can do localization of Widgets and Buttons.  But it is not reflecting on basemaps. I would like to localized basemap as well (i.e. city, country labels on map).
is it possible in Arcgis JS API ?
AnandPaleja
As per What’s new in Esri Vector Basemaps (March 2020) . Localization is supported in many locales. list is provided on the announcement page.
Egge-Jan_Pollé
Hi Anand,
With the ArcGIS JS API you can create new Basemap objects, which you can combine into a LocalBasemapsSource to be used in a BasemapGallery.
So, if you have any localized basemaps available you can follow this route to ad them to your map.
Here is a little example with basemaps for the UK from Ordnance Survey:
https://community.esri.com/people/EPolle_TensingInternational/blog/2020/03/24/arcgis-javascript-with...
HTH,
Egge-Jan
AnandPaleja
Hi Egge-Jan Pollé,
Thank for quick response.
I am aware about LocalBaseMapSource. My question is does default basemaps support localization ? if so how I can switch language.
AnandPaleja
