Error when importing a feature class in a geodatabase file
1994
06-30-2020 06:01 AM
GeorgeVINA
Hello everyone,
I am trying to import a feature class from an shapefile or another geodatabase to a new empty file geodatabase.
It returns me an error 000210: Cannot create output/ The item was not found. The version of ArcGis is  10.3.1.
It creates just an empty table with the name of the feature class.
When i try to do the same operation in the same directory with the personal geodatabase, all works fine.
Do you have any ideas ?
Robert_LeClair
Esri Esteemed Contributor
George - a couple things, when you're completing the output parameter - are you double clicking on the file geodatabase to "go-in" to it and then typing the output feature class name?
In addition, there's some good information in this GeoNet thread.
Related - the Tool Reference page for ArcGIS Pro lists a solution here. Sometimes it's as easy as using File Explorer and right clicking the folder that the file geodatabase is located, right-click->Properties and uncheck the "Read-Only" box.
