When I try to open an image in “Oriented Imagery Viewer”, it is shows Failed to fetch error In imagery viewer
2017
06-29-2020 11:51 PM
PawanKumar1
#When I try to open an image in “Oriented ... | GeoNet, The Esri Community | GIS and Geospatial Professional Community
After successfully creation of oriented imagery catalog i am try to Open an image in the Oriented Imagery Viewer
When i Click somewhere on the map with coverage it shows "Failed to fetch" massage in oriented imagery Viewer.
Please help me to resolve this issue.
Image preview
Randall_XavierRebello
Hi Pawan,
Are you still facing this error? Can you check the path for the data that you have added to the OIC. You can do this by looking at the attribute table of the Exposure Points feature class. If the path is pointing to a location on your local hard drive then it will not work. The image location should be a web based location, so typically the path should start with http:// or https://.
The other possibility if it is already on the web (cloud storage) is that you dont have permission to access the data. resource.
Randall
SoukainaMENJEL
And now it works? how you resolve it? Esri
This error is due to S3 bucket permissions.
You can have a look at these links and check what works for you.
How do I edit public access settings for S3 buckets? - Amazon Simple Storage Service
Make sure you uncheck the option to unblock public access. If it is already unblocked then check the sub headings and unblock those as well.
You will also need to set CORS policy.
If you are not familar with this please check with your network admin or someone who is familiar with it.
How do I add cross-domain resource sharing with CORS? - Amazon Simple Storage Service
Randall
SoukainaMENJEL
I want to ask you about DepthImg in Oriented Viewer Imagery, how can i
define it? i put the accuracy values, it shows me that the widget of
measurement is added, location, distance, area, elevation. distance and
area cannot be clicked, so i will configure the depthImg, i i don't know
how, can you tell me more and give me an example what i would put on the
field and the attribute table.
Thank you so much.
Le mar. 6 oct. 2020 à 16:56, Randall Xavier Rebello <geonet@esri.com> a
écrit :
<https://community.esri.com/?et=watches.email.thread>
Re: When I try to open an image in “Oriented Imagery Viewer”, it is shows
reply from Randall Xavier Rebello
<https://community.esri.com/people/rrebello-esristaff?et=watches.email.thread>
in Imagery and Remote Sensing - View the full discussion
<https://community.esri.com/message/957362-re-when-i-try-to-open-an-image-in-oriented-imagery-viewer-it-is-shows-failed-to-fetch-error-in-imagery-viewer?commentID=957362&et=watches.email.thread#comment-957362>
