Add graphics along selected line
1606
06-24-2020 10:40 AM
BrianBulla
Honored Contributor
What I'm trying to figure out is a way to add graphics to the map, at specific distances along a selected line.  See my example below.  The user selects a line segment, then a database is queried that shows all of the sanitary sewer connection lines along that line.  What I want to do is to put a point on the screen at each specified distance (starting at the start or end of the line) to show where each connection is.
I've never messed with graphics in ArcGIS Pro SDK before, so any guidance is appreciated.
Thanks!
UmaHarano
Hi Brain,
At 2.5 and previous versions, you can use Map overlays to create graphic elements on your map. GeometryEngine provides methods to calculate the sewer connection points along the line. You can create your graphic elements at these points. MapOverlay samples
New at 2.6: GraphicsLayer API will be available and you can alternatively also use that to create the elements.
Uma
UmaHarano
Hi Brain,
Uma
BrianBulla
Honored Contributor
Hi Uma Harano‌,
I've pretty much got this working, but the one thing that is causing me problems is the removal of the graphics when I select a new row in my table to add new points.  Only the most recently added overlay point gets removed.  I'm basically using the same code as from the Geocode sample to do this.  Here is my OverlayUtils code:
namespace SAWS_Sewer_Connections
    class OverlayUtils
        private static System.IDisposable _overlayObject = null;
        public static void RemoveFromMapOverlay(MapView mapView)
            if (_overlayObject != null)
                _overlayObject.Dispose();
        public static void UpdateMapOverlay(ArcGIS.Core.Geometry.MapPoint point, MapView mapView)
            //if (_overlayObject != null)
            //    _overlayObject.Dispose();
            //    _overlayObject = null;
            //    AddToMapOverlay(point, mapView);
            //else
            //    //first time
        public static async void AddToMapOverlay(ArcGIS.Core.Geometry.MapPoint point, MapView mapView)
            ArcGIS.Core.CIM.CIMPointSymbol symbol = null;
            await QueuedTask.Run(() =>
                // Construct point symbol
                symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 5, SimpleMarkerStyle.Square);
            //Get symbol reference from the symbol
            CIMSymbolReference symbolReference = symbol.MakeSymbolReference();
                _overlayObject = mapView.AddOverlay(point, symbolReference);
And here is the code I run when the selection in my ListView changes:
foreach (var oid in selectedOIDs)
                            var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
                            insp.Load(gsFLayer, oid);
                            //Get the To and From point of the currently selected feature
                            var pointCollection = ((ArcGIS.Core.Geometry.Multipart)insp.Shape).Points;
                            if (currentSurvey.direction == "U")
                                fromPoint = pointCollection[pointCollection.Count - 1];
                            else
                                fromPoint = pointCollection[0];
                            //MessageBox.Show(insp["FACILITYID"].ToString() + " - " + fromPoint.X.ToString() + ", " + fromPoint.Y.ToString());
                            MapView mapview = MapView.Active;
                            OverlayUtils.RemoveFromMapOverlay(mapview);
                            ArcGIS.Core.Geometry.MapPoint connPoint = null;
                            double theLength = ((ArcGIS.Core.Geometry.Multipart)insp.Shape).Length;
                            foreach (var currentDetail in lstDetails.Items.OfType<detailItems>())
                                    connPoint = ArcGIS.Core.Geometry.GeometryEngine.Instance.QueryPoint((ArcGIS.Core.Geometry.Multipart)insp.Shape, ArcGIS.Core.Geometry.SegmentExtension.NoExtension, theLength - (double)currentDetail.distance, ArcGIS.Core.Geometry.AsRatioOrLength.AsLength);
                                else
                                    connPoint = ArcGIS.Core.Geometry.GeometryEngine.Instance.QueryPoint((ArcGIS.Core.Geometry.Multipart)insp.Shape, ArcGIS.Core.Geometry.SegmentExtension.NoExtension, (double)currentDetail.distance, ArcGIS.Core.Geometry.AsRatioOrLength.AsLength);
                                OverlayUtils.UpdateMapOverlay(connPoint, mapview);
                            //OverlayUtils.UpdateMapOverlay(fromPoint, mapview);
I guess they are all individual objecsts, but is there a way to get RemoveFromMapOverlay to remove everything, not just the last one created??
BrianBulla
Honored Contributor
I think I figured it out!  Adding all of the added overlays in a collection seems to work.
    class OverlayUtils
        private static IList<System.IDisposable> _allOverlays = new List<System.IDisposable>();
                foreach (var overlay in _allOverlays) overlay.Dispose();
            //else
            //    //first time
                _allOverlays.Add(_overlayObject);
Thanks Uma Harano‌!!
PaulORourke
Very helpful!  Thank you!
