How do I change webmaps used in a web mapping application?
1169
06-19-2020 12:44 PM
SteveLi
web_mapping_app_item.get_data() will give me a json object, which has a map property:
'map': {'3D': False,   '2D': True,   'position': {'left': 0, 'top': 40, 'right': 0, 'bottom': 0},   'itemId': 'xxxxxxx',   'mapOptions': {}},
I need to update the map's itemId property of the web mapping application, how do I do that?
VictorTey
Just like how you get the item data, you can do a update as well. See link below.
Please mark as correct if this helps you so it may help others as well.
arcgis.gis module — arcgis 1.8.1 documentation
Example
Using and updating GIS content | ArcGIS for Developers
SteveLi
Thanks for providing samples.
It's still not clear to me how to do it.  The item I need update is a web mapping application, not webmap.  The update on an item can only take following keys.  which key should I use?
Key
Value
type
Optional string. Indicates type of item, see URL 1 below for valid values.
typeKeywords
Optional string. Provide a lists all sub-types, see URL 1 below for valid values.
description
Optional string. Description of the item.
title
Optional string. Name label of the item.
url
Optional string. URL to item that are based on URLs.
tags
Optional string. Tags listed as comma-separated values, or a list of strings. Used for searches on items.
text
Optional string. For text based items such as Feature Collections & WebMaps
snippet
Optional string. Provide a short summary (limit to max 250 characters) of the what the item is.
extent
Optional string. Provide comma-separated values for min x, min y, max x, max y.
spatialReference
Optional string. Coordinate system that the item is in.
accessInformation
Optional string. Information on the source of the content.
licenseInfo
Optional string. Any license information or restrictions regarding the content.
culture
Optional string. Locale, country and language information.
access
Optional string. Valid values are private, shared, org, or public.
commentsEnabled
Optional boolean. Default is true, controls whether comments are allowed (true) or not allowed (false).
