ArcPy fails to initialize Python 3
2205
9
06-19-2020 11:33 AM
by Anonymous User
Not applicable
When launching a python script from a SQL Server Agent Job I am unable to initialize a product license (We are using ArcPro) which is causing my import arcpy statement to fail. I know its a long shot but do any of y'all have an idea on how to fix this?
-Ben
JoeBorgione
How are you managing your licenses?  It gets a little tricky when using AGOL named users.  I'm curious as to why you are using sql server agent to fire an arcpy script: we have a system user do it, and that system user is also a named user at agol so it can grab the license.
MichaelVolz
Esteemed Contributor
Is this script gong to be part of an on-going process that will be run as a Windows Scheduled Task?
JoeBorgione
Michael Volzl ; all of our scripts run as scheduled tasks not through sql server agent...
by Anonymous User
Not applicable
So we are running this script after an insert trigger is fired. We currently run it as a scheduled task but have received requests to have it run after records are inserted into a database. We have a named user license that is authorized to work offline on the machine.
JoeBorgione
I don't know how you would convince the license part that sql server agent is the same as the user name that runs your scheduled tasks. That's a funky one.
Would you consider an attribute rule that fires upon insert?
by Anonymous User
Not applicable
I would. Can you provide documentation for me to go down that rabbit hole? I really appreciate the help.
MichaelVolz
Is this an enterprise geodatabase?  If so, would that require that the Attribute Rule be run against a feature service where the enterprise geodatabase is the source?
by Anonymous User
Not applicable
It is an enterprise gdb yes. As for your second question technically I think so?
JoeBorgione
Attribute rules:  Introduction to attribute rules—Geodatabases | Documentation
Any attribute rule(s) are assigned to a specific attribute in the specific feature class.  I believe if that feature class is a published, editable feature layer/service the attribute rules are fired back in the enterprise gdb, so you'd be good to go.
