select by attribute LIKE another attribute value
1998
06-16-2020 12:22 PM
LJackson29
I want to use Select by Attribute to select records where the value in one attribute is LIKE the value in another attribute, so for example:
PIN_TRACKING LIKE '%PIN%'
Where PIN_TRACKING is a list of PINs and I want to identify if PIN is listed in PIN_TRACKING
PIN           PIN_Tracking
1               1,2,3
2               4,5
3               1,2,3
So for the above data it would select record 1 and 3 as the PIN is included in the list in PIN_TRACKING
Thanks for your help!
Tags (1)
DanPatterson
MVP Esteemed Contributor
not sure where you are doing this... field calculator?, script? within the select by attribute, but conceptually
IF PIN is numeric and PIN_TRACKING is text...
p = 1
pt = '1,2,3'
str(p) in pt  # ---- where p and pt are their associated fields
True
... sort of retired...
LJackson29
Thanks - I am trying to do it in Select by Attribute. Both are text fields.
DavidPike
MVP Notable Contributor
Bit of a stumper actually, I might just add a new field and run a field calculator expression on it to return 0 or 1 or something like that. then select by attributes where the new field = 1.
#pre-logic python
def checker(PIN, PIN_TRACKING):
   if PIN IN PIN_TRACKING.split(","):
       result = '1'
   else:
       result = '0'
   return result
#window
checker(!PIN!, !PIN_TRACKING!)
JoeBorgione
I guess you want to do this interactively?  I could see doing it with a python script using a search cursor (untested!!😞
import arcpy
fc = r'C:\path\to\gdb\featureClass'
fields = ['OBJECTID', 'PIN', 'PIN_Tracking']
arcpy.MakeFeaturelayer_management(fc, 'fcLyr')
with arcpy.da.SearchCursor('fcLyr', fields) as cursor:
    for row in cursor:
        select = 'OBJECTID = row[0]'
        if row[1] in row[2]:
            arcpy.SelectLayerByAttribute_management('fcLyr','ADD_TO_SELECTION',select)
I've always thought it would be cool to add a condition to the interactive select by attributes tool...
