What is the proper way to reproject a geometry object using arcpy?
2717
06-10-2020 10:15 AM
EricEagle
I am working with a geometry object projected in EPSG 6455 but would like to add its extent to a feature class that is in EPSG 4326.
arcpy.Project_management() wants a feature class as input and output.
Here's what I've got so far (please note that using ZLAS is in no way an endorsement of ZLAS as a proprietary format)
### ZLAS testing ###
zlas = "C:/Data/USGS_LPC_IL_4County_Cook_2017_LAS_15008550_LAS_2019.zlas"
des = arcpy.Describe(zlas)
print(des.dataType)
print(des.spatialReference.factoryCode)
print(des.extent)
polys = []
las_extent = [
                [des.extent.YMin, des.extent.XMin],
                [des.extent.YMax, des.extent.XMin],
                [des.extent.YMax, des.extent.XMax],
                [des.extent.YMin, des.extent.XMax]
for coord_ring in las_extent:
    poly = arcpy.Polygon(arcpy.Array([arcpy.Point(*coords) for coords in coord_ring]), arcpy.SpatialReference(6455))
    polys.append(poly)
How would I coerce "poly" from 6455 to 4326 without incurring the IO expense of writing feature classes?
The background, if useful: I am plowing through a directory structure with thousands and thousands of point clouds.  The intent is to gather their extents, add them to a global feature class, and then serve that feature class up as a service identifying where all of our holdings are, allowing users to browse our holdings geographically rather than trying to hunt through a directory tree.  Because many of the files are projected differently (some requiring transformation - default transformation being fine as this isn't high precision) I want to harmonize them all into a single GCS feature class.
DanPatterson
MVP Esteemed Contributor
Like this example in
Polygon—ArcPy classes | Documentation
projectAs (spatial_reference, {transformation_name})
ParameterExplanationData Type
spatial_reference
The new spatial reference. This can be a SpatialReference object or the coordinate system name.
SpatialReference
transformation_name
The geotransformation name.
String
... sort of retired...
DanPatterson
spatial_reference
SpatialReference
transformation_name
String
EricEagle
Thanks Dan...  Sometimes one just needs a pointer to the right doc. I tell ya, if the Esri UC was happening this year I'd hunt you down and buy you an adult beverage of your choice.  Really appreciate all the help.
DanPatterson
I will be online
