Issue while showing column chart
1375
06-05-2020 11:35 AM
ShaikhRizuan
I am not able to show column chart in pop-up window of map click. I am not getting any error message also in console.
<!DOCTYPE html>
<html>
<head>
<title>Info Window with Chart</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.32/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.32/esri/css/esri.css">
<style>
html, body, #map {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
.chart {
width:200px;
height:200px;
padding:0px !important;
</style>
<script src="https://js.arcgis.com/3.32/"></script>
<script>
var map;
// Try other themes: Julie, CubanShirts, PrimaryColors, Charged, BlueDusk, Bahamation, Harmony, Shrooms
var theme = "Wetland";
require([
"esri/map", "esri/layers/FeatureLayer",
"esri/dijit/InfoWindow", "esri/InfoTemplate",
"esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
"dijit/layout/ContentPane", "dijit/layout/TabContainer",
"dojox/charting/Chart2D", "dojox/charting/plot2d/Columns",
"dojox/charting/action2d/Highlight", "dojox/charting/action2d/MoveSlice", "dojox/charting/action2d/Tooltip",
"dojox/charting/themes/MiamiNice",
"dojo/dom-construct", "dojo/dom-class",
"dojo/number", "dojo/domReady!"
], function(
Map, FeatureLayer,
InfoWindow, InfoTemplate,
SimpleFillSymbol, SimpleRenderer,
ContentPane, TabContainer,
Chart2D, Columns,
Highlight, MoveSlice, Tooltip,
MiamiNice,
domConstruct, domClass,
number, parser
// Use the info window instead of the popup.
var infoWindow = new InfoWindow(null, domConstruct.create("div"));
infoWindow.startup();
map = new Map("map", {
basemap: "streets",
center: [-113.405, 43.521],
infoWindow: infoWindow,
zoom: 6
map.infoWindow.resize(275, 275);
var template = new esri.InfoTemplate();
// Flag icons are from http://twitter.com/thefella, released under creative commons.
template.setTitle("<b><img src='flags/${STATE_ABBR}.png'> ${STATE_NAME}</b>");
template.setContent(getWindowContent);
var statesLayer = new FeatureLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5", {
mode: FeatureLayer.MODE_ONDEMAND,
infoTemplate: template,
outFields: ["*"]
var symbol = new SimpleFillSymbol();
statesLayer.setRenderer(new SimpleRenderer(symbol));
map.addLayer(statesLayer);
function getWindowContent(graphic) {
// Make a tab container.
var tc = new TabContainer({
style: "width:100%;height:100%;"
}, domConstruct.create("div"));
// Display attribute information.
var cp1 = new ContentPane({
title: "Details",
content: "<a target='_blank' href='https://en.wikipedia.org/wiki/" +
graphic.attributes.STATE_NAME + "'>Wikipedia Entry</a><br><br>Median Age: " +
graphic.attributes.MED_AGE + "<br>Median Age (Male): " +
graphic.attributes.MED_AGE_M + "<br>Median Age (Female): " +
graphic.attributes.MED_AGE_F
// Display a dojo pie chart for the male/female percentage.
var cp2 = new ContentPane({
title: "Pie Chart"
tc.addChild(cp1);
tc.addChild(cp2);
// Create the chart that will display in the second tab.
var c = domConstruct.create("div", {
var chart = new Chart2D(c);
domClass.add(chart, "chart");
// Apply a color theme to the chart.
chart.setTheme(MiamiNice);
chart.addPlot("default", {
type: "Columns",
markers: true,
gap: 5
tc.watch("selectedChildWidget", function(name, oldVal, newVal){
if ( newVal.title === "Columns" ) {
chart.resize(180,180);
// Calculate percent male/female.
var total = graphic.attributes.POP2000;
var male = number.round(graphic.attributes.MALES / total * 100, 2);
var female = number.round(graphic.attributes.FEMALES / total * 100, 2);
chart.addAxis("x");
chart.addAxis("y", { vertical: true, fixLower: "major", fixUpper: "major" });
chart.addSeries("PopulationSplit", [{
x:0,
y: male,
tooltip: male,
text: "Male"
x:0,
y: female,
tooltip: female,
text: "Female"
//highlight the chart and display tooltips when you mouse over a slice.
new Highlight(chart, "default");
new Tooltip(chart, "default");
new MoveSlice(chart, "default");
cp2.set("content", chart.node);
return tc.domNode;
</script>
</head>
<body class="claro">
<div id="map"></div>
</body>
</html>
Regards,
Noah-Sager
If you want to upgrade to 4x, here is a really nice sample that shows how to use various elements in a popup: Multiple popup elements | ArcGIS API for JavaScript 4.15
KellyHutchins
Esri Notable Contributor
If you are unable to upgrade to 4.x try the following:
Instead of using the Info Window try removing the code that sets the Info Window as the default popup.  Once you've done that you will be using the Popup and can take a look at the Popup chart sample here: Popup | ArcGIS API for JavaScript 3.32
