Define Projection Not working
5079
5
06-03-2020 05:01 AM
MJune
I am trying to use the Define Projection tool and a feature class in an enterprise geodatabase.  I am receiving an error that it can't create a projection file (ERROR 000054).  I have confirmed there is no locks on the table, the user logged in is the owner of the table and has db owner on the database.  I am using a standard license.  I've tried in both Pro and ArcCatalog (10.5.1).  I've tried several tables with the same result.  Is there security I am missing?  Can there not be any locks on any table/view in the database while running the tool?
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
From the screenshot, the FC appears to be a stand-alone FC in the root level and not a FC in a feature dataset participating in a special relationship, like geometric network, topology, etc...  Correct?
Check the database logs.  If it is an issue on the DBMS that is forcing the error on the client, the logs should help you find the issue.
MJune
You are correct, this is a stand along feature class. I will see what we can find in the database logs
Thank You,
Melissa
ManuKaur
This documentation may be of some help to you.
000054: Cannot create a projection file for .—Help | Documentation
I suggest double checking that the output is not read only.
NicolasGIS
Honored Contributor
Hello @MJune ,
Out of curiosity, are you on Oracle ? I opened a BUG less than a year ago regarding this issue:
BUG-000152217: In ArcGIS Pro, the Define Projection tool fails to assign a projected coordinate system for Oracle geodatabase feature classes.
Upgraded yesterday to latest SDE version, still not fixed...
vijaybadugu
I am also facing same issue with SQL Server. I was trying to use define projection for a spatial and it always throws error and even after restarted the desktop . I don't have any clue on this
