Add a feature class to a map in Jupyter Notebook
3571
06-03-2020 07:51 AM
YaoTang
Can I add a field of a feature class to a map using something like map1.add_layer(FeatureClassName, FieldName, SymbologyType, ColorMap)?
DanPatterson
MVP Esteemed Contributor
Notebooks from inside or outside of ArcGIS Pro?
you can use the arcgis and the arcpy modules.
It would be kind of useless to make a map inside a notebook inside of Pro, since you can just look at the map there.
There is webmap stuff and other things in
API Reference for the ArcGIS API for Python — arcgis 1.8.0 documentation
and the arcpy mapping module
Introduction to arcpy.mp—ArcPy | Documentation
... sort of retired...
alex_friant
Yes you can, sort of. You can't directly view the Feature Class (FC), but if you want to see what the data looks like in a map, you can convert it to a Spatially Enabled DataFrame (SeDF), and then plot that on a map in Jupyter Notebooks. Just keep in mind that your FC and the SeDF are disconnected. If you make changes to your FC then you will need to update the SeDF.
This is one way to do it that I use:
# import modules
import pandas as pd
from arcgis.features import GeoAccessor, GeoSeriesAccessor
from arcgis.gis import GIS
# create map
gis = GIS()
my_map = gis.map(location = 'San Francisco, CA', zoomlevel = 12)
# load your feature class into a spatially enabled dataframe (sedf)
fc = r'c:\gis\my_geodatabase.gdb\firestations'
my_sedf = pd.DataFrame.spatial.from_featureclass(fc)
# plot the sedf on your map
my_sedf.spatial.plot(map_widget = my_map)
# show the map
my_map
example plot
BBowers_napacounty
Hi Alex,
How would one go about adding labels to these points so they display in the map widget?
Thanks!
Brian
