Average from feature set using a variable?
802
05-19-2020 11:47 AM
MartinOwens1
Goal: Create a feature set from an intersection of another layer then filter based on a field value. From there I need to define a numeric score value from a string, and finally return the average of the numeric score from the feature set .
The issue I'm having is getting just the feature set to calculate the average for.
//Finds the Neighborhood Polygon that intersects with Selected Parcel
var intersectArea = Intersects(FeatureSetByName($map,"Neighborhoods"), $feature);
//Defines the field to match and set the filter with
var nbhd = $feature.NBHD;
//Filters all parcels with the same NBHD as the selected feature
var filterresult = Filter($layer, 'NBHD = @nbhd');‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
//This returns the feature set I would like to assign a variable to and calculate an average from
CDU is the field I would like to add a numeric score to average:
if (CDU=="FAIR"){
    var cduVal = 1.25
} else if
    (CDU=="AVERAGE"){
     var cduVal = 1.5
} else if
    (CDU=="EXCELLENT"){
     var cduVal = 2.5
} else if
    (CDU=="EXTREMELY POOR"){
     var cduVal = 0.0
} else if
    (CDU=="GOOD"){
     var cduVal = 2
} else if
    (CDU=="POOR"){
     var cduVal = 1
} else if
    (CDU=="UNSOUND"){
     var cduVal = 0.25
} else if
    (CDU=="VERY GOOD"){
     var cduVal = 1.5
} else if
    (CDU=="VERY POOR"){
     var cduVal = 0.75
else {var cduVal = 0}
return Average(cduVal);
If that makes any sense...
Any help would be appreciated.
