Ingesting Archived Waze JSON Reports into ArcGIS
726
05-17-2020 02:53 PM
PaulRobinson1
We have files of archived (as opposed to a live feed) JSON Waze Road Closure reports (text files) that we want to ingest and display in ArcGIS.  We wanted to know if anyone has experience in setting this up and if there are scripts/packages that can take care of this. We are building our process but wanted to see if anyone has some tools we could use.
EricIronside
Hey,
I would use a Watch a Folder for new JSON files input to read the files in.  If there aren't a lot of files, you could copy them by hand one at a time into the folder that is being watched.  If there are a lot of them, you could set up a python script to do it at a sustainable rate.
Just be sure to copy them into the watched folder using a different extension than is being watched for and rename them once they are copied.  Basically, you want to be sure all the data is written to the file in the watched folder BEFORE GeoEvent tries to open it up and read it.  For example, set GeoEvent up to watch for *.json files, copy all of the data files in as *.txt files, then rename them one by one to have the *.json extension.
More details can be found in the following blog: https://community.esri.com/people/eironside-esristaff/blog/2019/04/11/geoevent-input-watch-a-folder-...
