How to change or remove selection colour in 4.15?
2143
05-15-2020 04:32 AM
ChristianBischof
I have a similar question as it was asked years ago in this thread:
   https://community.esri.com/thread/116957
Whenever an item is selected on my webmap it gets this default cyan colour. Is there any possible way to disable this functionality?
I am using JS API 4.15
Thanks in advance!
RobertScheitlin__GISP
This works fine for me:
        var view = new MapView({
          container: "viewDiv",
          map: map,
          center: [-101.94981250000075, 41.20977753557709],
          zoom: 5
        view.popup.highlightEnabled = false;‍‍‍‍‍‍‍‍
Christian.
  Have you seen the highlightEnabled property of the views popup?
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Popup.html#highlightEnabl...
ChristianBischof
Thanks Robert Scheitlin, GISP‌ but this highlightEnabled property seems not to work for me. Despite that you gave me some inspiration to solve the problem by using the following properties on my mapview.
map: webmap,
highlightOptions: {
   color: [255,255,255,0]
I've achieved, what I wanted, despite that I'd like to know how you'd have solved this problem with the property you mentioned.
          map: map,
          zoom: 5
