Stage Data Loading Failed
1574
05-10-2020 02:18 AM
Md_TauhidulIslam
I was trying to configure the data loading for Water utilities It failed with the following error.
in the data loading project location the default gdb had sample data of US. I replaced the gdb with my gdb. is there any procedure for that or am I missing something here? utility network project folder contains default gdb with utility network.
Regards,
Tauhid
MarcoBoeringa
The error message includes a warning about an emtpy geometry, indicating the integrity of the geometries in your input features class may be compromised. I recommend running the Repair Geometry—Data Management toolbox | Documentation tool to check and repair any invalid geometries before attempting to load the data using the Stage Data Loading tool.
MikeMillerGIS
Esri Frequent Contributor
What version of Arcgis Pro are you using? That tool looks like a dev tool that was never released. You want to install the data loading tools and use them.
https://solutions.arcgis.com/shared/help/data-loading/
MikeMillerGIS
Nevermind, that tool is part of the data loading solutions.  It is failing on running change asset package spatial reference, could you try running that tool using the asset package in that project and your spatial reference?
