Keyboard shortcut - create points
3923
10
04-30-2020 11:23 AM
ScottSweet
Is there a keyboard shortcut for creating points?  I can't find one anywhere in the documentation.  This seems like it would be the easiest shortcut to implement ever.  Do I really have to use a different GIS software to avoid thousands of mouse clicks?
DanPatterson_Retired
If you don't care where they go, you can create lots with a few clicks....
Create Random Points—Data Management toolbox | Documentation
but what would a keyboard shortcut do?   bring up a tool? or replace a mouse click?
ScottSweet
Thanks Dan,
I don’t need to create random points. I need to digitize thousands of macadamia nut trees in an orchard. So instead of clicking the mouse button 10,000 times, or hiring an intern to do so I’d like to be able to hover the mouse over the location I need to place the point and push the “p” character on the keyboard to create a new point there, for example.
Scott
Keyboard shortcuts for editing—ArcGIS Pro | Documentation
Create point features
Keyboard shortcutFunctionDescription
F6
Absolute X,Y,Z Absolute XYZ
Opens the Absolute X,Y,Z dialog box.
but I doubt you want to add the x, y values manually.
If you are creating the featureclass and hovering over a location, a mouse click would be easiest.
ScottSweet
It isn’t easy when you have to click tens of thousands of times. I’d much rather push a button on a keyboard than click that many times. My finger gets tired! I guess I’ll have to use a different software if repetitive movement and health is not a concern of ESRI. Seems silly to not be able to incorporate something like this. I’ve tried deep learning to automatically detect the trees but no matter how I tweak the model it doesn’t do a good job at all in our orchards. So I’m stuck with click click click click…
Kory Kramer
... if repetitive movement and health is not a concern of ESRI. ...
anyone on the ergonomics team have an opinion on key stroke vs mouse click? or maybe a candidate for an addition to the shortcuts
ScottSweet
I would appreciate that Kory. In other software (Geocap AS) when digitizing points they have the option to use the P character or space bar. It saves me a lot of grief when I have to create many point features. But in order to use Geocap for this task I'd have to do a lot of conversions/import/export and re-import to ArcGIS.
Scott
Get Outlook for Android<https://aka.ms/ghei36>
If you have a laptop with a touchpad, you can simply use the mouse to point, then hit the touch pad to add the point.
Works for me at least (Surface Book 2).
ScottSweet
Thanks for the suggestions. I changed the settings on my touchpad to still work when I have a mouse plugged in and that way I can use the button on the touchpad when my click finger gets tired, and alternate back and forth.
Scott
KoryKramer
Esri Esteemed Contributor
Have you experimented with Use ArcGIS Pro with a keyboard—ArcGIS Pro | Documentation ?
I personally have not since I don't have a numpad on my laptop, but would be interesting to see if it serves the purpose.
If it doesn't, then submitting an idea on ArcGIS Ideas‌ would be needed since currently I don't believe there is a way to assign a shortcut key for 'mouse click'.
