revised: how can I access className?!
1098
04-30-2020 09:30 AM
CamCode
Revised attempt at my previous question:
I am successfully adding a class to my graphic layer.... previously I was using an ID.. I console.log(myNewGraphicLayer) and it's found, the added class below: vvv
  1. attributionDataUrl: (...)
  2. attributionVisible: (...)
  3. className: "someThing" <-----------------------------------
  4. elevationInfo: (...)
  5. fullExtent: (...)
  6. graphics: (...)
  7. hasAttributionData: (...)
  8. id: (...)
  9. legendEnabled: (...)
  10. listMode: (...)
  11. load: ƒ (e)
  12. loadError: (...)
I added it this way: vvvv
    let graphicsLayer = new GraphicsLayer({
      //id: "someThing", <------- works, but I am adding many need to use class
I am perplexed, because this will work when ID is added...
const polyDrawline = map.findLayerById('someThing');
but this will not work when className is added...
const polyDrawlineS = map.findLayerByClassName('someThing');
how do I access my className?
Tags (1)
RobertScheitlin__GISP
Cam,
     The map class does not have a method by that name.
https://developers.arcgis.com/javascript/latest/api-reference/esri-Map.html#methods-summary
What exactly are you trying to do? Will the findLayerById not work for you?
