Can you make GDBs or feature classes "read only" access with no "editing/write" access?
3207
04-24-2020 02:36 PM
deleted-user-FmkhXNDiaqAF
I know you can license a GDB which requires the end user to need license key, but is there a way to make GDBs or feature classes or shapefiles "read only" so the end user cannot edit the data? I saw somewhere that the only way to do this is to set the permissions in the Windows folder on Explorer to "Read only". Is that correct?
JoshuaBixby
MVP Esteemed Contributor
If managing permissions/access to data is important, the best option is to work with enterprise geodatabases.  You can compress a file geodatabase, which makes it read-only, but someone could uncompress it if they want.  Also, there can be issues with certain workflows/tool and compressed data.  Since file geodatabases are file-system based, you can also make the folder read-only as you have already read about.
There is no security model built into file geodatabases (licensing isn't really a security model) so there is no proper way to secure them.  If you shared why you want to make the file geodatabase read-only, people might be able to provide additional ideas.
EdJuarbe
Although not directly from a GDB, if you have access to ArcGIS Online (I assume so if you have ArcGIS Enterprise database), or ArcGIS Portal (Server), you can publish a map service.  This will render those layers to be uneditable.  From there, you can create a web map and/or web app to view the data.  If using ESRI desktop apps, you can also pull the published service layers into your GIS mapping application.
