Rendered problem with 2 FeaturesLayers created from JSON
1301
04-23-2020 12:56 AM
IonutAlixandroae1
Hi all,
I have a simple map with 2 layers in it. The layers are FeatureLayers created by specifing the "rings" from JSON. On top of that, a simple renderer with simple fill is applied.
My problem is that 1 layer is correctly displayed and the second is not, meaning only the countour is the layer, and inside is like a hole.
Not sure if this is a problem with the renderer or with the json data.
Please see example here: https://codepen.io/ialixandroae/pen/yLYgzYv
Correct polygon:
Error polygon:
The layers are created from these 2 jsons:
1. const aoi1 = {"type":"Polygon","coordinates":[[[35.7129570843,35.5924058435],[35.8406162505,35.5924058435],[35.8406162505,35.4837313832],[35.7129570843,35.4837313832],[35.7129570843,35.5924058435]]],"crs":{"type":"name","properties":{"name":"EPSG:4326"}}}
2. const aoi2 = {"type":"Polygon","coordinates":[[[22.625794,44.166363],[22.744446,44.166363],[22.744446,44.27656],[22.625794,44.27656],[22.625794,44.166363]]],"crs":{"type":"name","properties":{"name":"EPSG:4326"}}}
If I test the aoi2 in the application geojson.io , basically take aoi2 data and throw it in the right panel, then in the map I get a whole polygon, no hole or contour, but with JS API I have this situation...
Many thanks!
RalucaNicola1
Hi Ionut,
the winding order for your second polygon is not correct, it should be counter-clockwise for outer rings. I swapped the vertices and it should display correctly: https://codepen.io/ralucanicola/pen/bGVgYKz?editors=0010
I was sure that this would be in the documentation, but it seems it isn't. I'll make sure to add that to the doc, thanks for the feedback!
Raluca
RalucaNicola1
Hi Ionut,
Raluca
IonutAlixandroae1
Thank you very much Raluca!
I was thinking that the coordinates array might be the problem here but it didn`t not even cross my mind about the winding order
Yup, good idea to update the docs.
Thanks again for your help!
Best,
Ionut
