Register Database Inside ArcGis Server
1177
04-18-2020 05:28 AM
MohammedAlsaad
Hi Everyone,
I have a problem when registering the database inside (ArcGis Server Properties).
When I do that the following message appears:
But when I register the database in (ِArcGis Catalog) no problem appears. And everything is fine.
I install arcgis Enterprise 10.7 Include (arcgis desktop, arcgis server, arc portal, arcgis Data Store, and arcgis Web adaptor).
and I install oracle client database v11g.
and i work in windows server 2012.
arc gis 10.7 arcserver enterprise
can any one help me ?
Asrujit_SenGupta
ArcGIS Desktop is a 32-Bit Application and hence needs the Oracle 32-Bit client. Whereas, ArcGIS Server is 64-Bit and hence will need the 64-Bit Oracle Client to be configured.
If ArcGIS Desktop and ArcGIS Server are on the same server, you need both the 32-bit and 64-bit clients. And in the Environment Path Variable, have the 64-Bit Oracle Client before the 32-Bit Client. Once done, restart the ArcGIS Server Service and then try Registering the Database.
Error: Client software failed to load. Be sure the database client software is installed and configu...
