Limit the fields in Query Widget (Export to CSV)
3924
10
04-04-2020 04:09 AM
KrishV
Hi All,
I have seen Robert Scheitlin, GISP solution on below link and tried the same using WAB 2.15 but all the fields are getting downloaded in my csv.
Web App Builder - How to limit fields in "export to CSV" option in query widget?
I have tried below code:
 var resultfields = [];
        for (i=0; i< popupInfos.length-1; i++){
            if (popupInfos[i].visible == true){
                resultfields.push(popupInfos[i].fieldName)
 var fFlds = array.filter(layer.fields, lang.hitch(this, function(fldInfo) {
   return  resultfields.indexOf(fldInfo.name) > 0;
var featureSet = new FeatureSet();
featureSet.fields = lang.clone(fFlds);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Please help.
Krish
RobertScheitlin__GISP
Kirsh,
  Sorry I was looking at 2.14. 2.15 has changed yet again how they handle CSV export.
In the exportUtils.js change this method (line 7):
      exportCSV: function() {
        return this.getFeatureSet().then(lang.hitch(this, function(fs){
          var popupInfo = this.findPopupInfo(fs);
          var layerDefinition = this.findLayerDefinition(fs);
          var features = fs.features;
          if (layerDefinition && layerDefinition.fields) {
//change here
            var outFields = lang.clone(fs.fields); //layerDefinition.fields);
            this._addXYAttribute(outFields, 'x');
            this._addXYAttribute(outFields, 'y');
            layerDefinition.fields = outFields;
            features = [];
            array.forEach(fs.features, lang.hitch(this, function(feature) {
              var graphic = new Graphic(feature.toJson());
              graphic.attributes = this._getAttrsWithXY(graphic);
              features.push(graphic);
          return CSVUtils.exportCSVByGraphics(
            this.filename,
            layerDefinition,
            features,
              formatNumber: true,
              formatDate: true,
              formatCodedValue: true,
              popupInfo: popupInfo
Also here is an update to the SingleQueryResult.js > _getFeatureSet function (to insure it get the first and last fields that were being skipped previously).
      _getFeatureSet: function () {
        var layer = this.currentAttrs.query.resultLayer;
        //get popup info for field alias
        var popupInfos = null;
        var popupInfoObj = this.currentAttrs.config && this.currentAttrs.config.popupInfo;
        if (popupInfoObj) {
          popupInfos = popupInfoObj.fieldInfos;
        for (i = 0; i < popupInfos.length; i++) {
          if (popupInfos[i].visible == true) {
            resultfields.push(popupInfos[i].fieldName);
        var fFlds = array.filter(layer.fields, lang.hitch(this, function (fldInfo) {
          return resultfields.indexOf(fldInfo.name) > -1;
        featureSet.features = [].concat(layer.graphics);
        featureSet.geometryType = layer.geometryType;
        featureSet.fieldAliases = {};
        array.forEach(featureSet.fields, lang.hitch(this, function (fieldInfo) {
          var fieldName = fieldInfo.name;
          var fieldAlias = this._getFieldAliasByPopupInfo(fieldInfo, popupInfos);
          featureSet.fieldAliases[fieldName] = fieldAlias;
        console.info(featureSet);
        return featureSet;
Krish,
   Have you tried to console.log the fFlds to see if it is getting what you expect?
KrishV
Hi Robert Scheitlin, GISP‌,
Yes. I'm getting expected fields only. But when clicked , on export to csv, i'm getting all the fields in downloaded csv file.
Krish
Krish,
   That thread was back using WAB 2.4. What version are you using?
KrishV
Hi Robert Scheitlin, GISP,
I'm using WAB 2.15.
Krish
Krish,
   So in version 2.15 (or earlier) they made a change in the jimu.js/exportUtils.js file that overrides the featureset.fields back to all the fields. to get past this you have to make a change to this file.
      _generateFields: function(featureSet) {
        var feature = featureSet.features[0];
        var fields, item, layerId;
        // if(feature._layer) {
        //   fields = feature._layer.fields;
        //   layerId = feature._layer.id;
Notice I have commented out lines 5-8 these are the lines that override the filtered fields that was already provided.
KrishV
I tried to find "_genereateFields" function in jimu.js/exportUtils.js file but unable to find it (WAB 2.15).
Do I have to create another function with this name?
I have tried by commenting below lines but still, it downloads all the fields:
findPopupInfo: function(featureSet) {
        if (!featureSet || !featureSet.features || featureSet.features.length === 0) {
          return null;
        var layerId;
        var fields;
          //fields = feature._layer.fields;
          //layerId = feature._layer.id;
          var layerInfos = LayerInfos.getInstanceSync();
          var layerInfo = layerInfos.getLayerInfoById(layerId);
          if (layerInfo) {
            var popupInfo = layerInfo.getPopupInfo();
            if (!popupInfo) {
              // Try another way to get popupInfo
              popupInfo = layerInfo.layerObject.infoTemplate && layerInfo.layerObject.infoTemplate.info;
            return popupInfo;
        return null;
 findLayerDefinition: function(featureSet) {
          return null;
//          return {
//            geometryType: featureSet.geometryType,
//            fields: feature._layer.fields
        var fields = [];
        var attributes = feature.attributes;
        var item;
        for (item in attributes) {
          if(attributes.hasOwnProperty(item)){
            fields.push({
        return {
          fields: fields
Krish
Kirsh,
//change here
            features = [];
            this.filename,
            layerDefinition,
            features,
              formatNumber: true,
              formatDate: true,
        if (popupInfoObj) {
        return featureSet;
KrishV
Thanks Robert Scheitlin, GISP! It worked Perfectly.
I'm just getting extra columns x and y in csv.
Krish
That is by design
