How to delete memory-workspace
19060
17
04-02-2020 11:25 PM
MattWeber2
how can I delete the memory-workspace after a script has run?
I usually added
arcpy.Delete_management("memory")
to the end of my scripts, but noticed yesterday that this apparently doesn't do anything.
The workaround i found is to loop over all fc in the workspace and delete them one by one.
for fc in arcpy.ListFeatureClasses():
    desc = arcpy.Describe(fc)
    arcpy.Delete_management(desc.catalogPath)
But this help site indicates it should be possible to delete all at once.
Write geoprocessing output to memory—ArcGIS Pro | Documentation
Also, the older in_memory seems to empty itself after a script ran, why doesn't memory do the same?
Cheers
edit: I am using ArcGIS Pro 2.4.3
DanPatterson_Retired
The help doesn't differentiate between in_memory and memory for deleting, as you have noted.
I couldn't find anything related to this on the support site (visible to mere mortals), but I stumbled on this
BUG-000120068: Loading data into a memory-workspace consumes about ..
Perhaps more lurks behind the (in_)memory divide.
JoshuaBixby
MVP Esteemed Contributor
How exactly are you running your script?  As a script tool from within Pro, as a stand-alone script using Pro conda?
MattWeber2
I run it as a script tool from within Pro.
The full script, might reveal more
MattWeber2
arcpy.AddMessage(arcpy.Exists(r"memory\copied"))
arcpy.CopyFeatures_management("to_copy", "memory\copied")
Output is
False, True, True the first time the script runs, True True True the second time and onwards
So line 4 doesn't do anything, and even after the Tool finished, fc in memory persist.
Replacing line 4 with the specific delete-call:
arcpy.Delete_management(r"memory\copied")
gives the expected result of False, True, False for any number of runs
If I use the older "in_memory" it works fine by the way.
arcpy.AddMessage(arcpy.Exists(r"in_memory\copied"))
arcpy.CopyFeatures_management("to_copy", "in_memory\copied")
arcpy.Delete_management("in_memory")
arcpy.AddMessage(arcpy.Exists(r"in_memory\copied"))‍‍‍‍‍‍‍‍‍‍
Output is:
False, True, False
And even if I remove line 4 and 5 the output is
False, True
for any number of runs. So the temporary fc saved in_memory are not kept in between runs.
JoshuaBixby
What version of Pro are you running?  I just tested your first code block as a script tool in ArcGIS Pro 2.5, and it returns False, True, False every time I run it.
MattWeber2
I am running 2.4.3.
Since nobody else can reproduce the behavior, I will resort to the workaround of deleting everything one by one for now.
Run from Spyder (IPython console).
dump AddMessage.... use print to rule it out as a culprit
# ---- test featureclass
copied = r"C:\Git_Dan\npgeom\Project_npg\tests.gdb\sq"
# ---- results for 'memory'
print(arcpy.Exists(r"memory\copied"))
arcpy.CopyFeatures_management(copied, "memory\copied")
False
True
False
# ---- results for 'in_memory'
print(arcpy.Exists(r"in_memory\copied"))
arcpy.CopyFeatures_management(copied, "in_memory\copied")
False
True
False‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Executable for the above
sys.executable
Out[9]: 'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\pythonw.exe'
Run from Python window in Pro
import arcpy
arcpy.CopyFeatures_management(copied, r"memory\copied")
False
True
False
False
True
False
the 'executable' from the python window inpro
import sys
sys.executable
'C:\\arc_pro\\bin\\ArcGISPro.exe'
Use print
MattWeber2
It works in IPython
sys.executable
'C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\python.exe'
but the same result in ArcGIS, Python window
or Toolbox
sys.executable
'C:\\Program Files\\ArcGIS\\Pro\\bin\\ArcGISPro.exe'
