I'm trying to get familiar with the Oriented Imagery Management tools and have been attempting to use the Copy Images to Web tool in order to get a series of test images from a 360 degree camera into an AWS S3 Bucket. I believe I have everything set up correctly however I keep getting a "NoSuchKey" error as seen in the screenshot below. Any guidance to get past this would be much appreciated.
Hi Ben,
This error is an returned from aws. Can you check the following link.
Troubleshoot the 404 NoSuchKey Error from Amazon S3
Check the permission of the cloud service profile that you are using. Ideally when you select a particular profile it should give you a list of all the buckets that you have permission to access. You have to make sure you select a bucket and then specify a folder in the bucket you want to copy the data to. If you want to copy it directly into the root folder of the bucket then you don't have to specify a folder.
Try copying the data using something like cloudberry to check if you can copy the data into the destination bucket/folder.
Randall
