Conditional requirements, but not using Relevant
1917
03-30-2020 09:48 AM
KorySteele
I'm building a survey for manhole inspections.  For a completed inspections, there could easily be 50+ fields with data.  However, there are very often times when we start an inspection but are unable to finish it, such as the manhole being surcharged.
I currently have a question that asks, is the inspection complete?  If yes, then I need nearly all of those 50 questions to have values in them.  If no, I still want all of the fields visible and fillable, and the data saved and submitted.
Using the relevant function with groups will not work for this.  I need the workers to see all the possible fields even if the inspection is not complete.  I've spent a couple of hours on researching this topic and have been unable to find a solution that works for me.
I'm a really new to Survey123 and I'm not a computer whiz, so sorry if this is a beginner question.
IsmaelChivite
Esri Notable Contributor
Hi Kory Steele‌. As you indicate, conditional statements on the relevant column are not the correct approach for this. First, because a question that is not relevant is always hidden, and you want the question to be visible. Second, because when a question is flagged as non-relevant, the Survey123 app will clear out its contents so users will be losing whatever they typed in.
I think what you can do is to use your conditional expressions in the required field.  The required field in the Survey123 Connect templates is pre-configured with a simple drop-down to say if the question is required (yes) or not (empty).  You can however type an XLSForm expression in there too. I am guessing that you could write something like  selected(${inspection_complete},'yes')  If the inspection is completed, then the question will be required. If not, it will not be required.
Would that work for you?
JenniferMcKee__GISP
So I am actually trying to implement a conditionally required question and I could not do this unless I removed the data validation (only allows field from the list, i think it's yes or empty cell) from the Required field for Survey123 Connect from ArcGIS. The survey was created in version 3.9.
DougBrowning
MVP Esteemed Contributor
The drop down just shows yes but you can but any true expression in there.  It does work.
