JSON as toolbox parameter
2138
03-28-2020 01:34 PM
jaykapalczynski
Honored Contributor
I am trying to pass some record data from Javascript to GP Service which accepts one parameter
I want to grab this parameter on the python side and parse it to variables.
I am missing something here.....Having issues....
I can pass a string to the python script so that part works....
I am just unsure of I have to JSON string formatted properly before I pass it from Javascript
or if I am trying to parse it incorrectly on the python side.....these are the steps I am taking...
Thoughts?
Step 1
Basically I am confused on how to create the JSON file on the javascript side....This will hold 3 records
I can format string to look like this and then set to JSON
var dict =  [  {'Results':
   ['address': 'some address', 'id': 'sone ID' , 'distance': 'some distance'],
var dictstring = JSON.stringify(dict);
gp.execute(dictstring );‍‍‍‍‍‍‍‍‍
Step 2
I then need to pass this to a GP service I set up with an input parameter called '"Request"
Question:
When setting up the parameters do I select "STRING" ???
Step 3
import arcpy
import json
jsondata = arcpy.GetParameterAsText(0)‍‍‍‍
for each in jsondata[Results][0]: ‍‍‍‍‍‍
   varId = (each['address'])
   varAddress = (each['id'])
   varDistance = (each['distance'])‍‍‍‍‍‍‍‍‍
   # do something with each of these record sets.‍‍‍‍‍‍‍‍‍‍‍
jaykapalczynski
Honored Contributor
solved
I was not setting up the params variable properly
nor was I handling the parameter in Python properly...
This works for me....any questions hit me up
var dictstring = '{"employees": [{ "address": "1520 Split Oak Ln, Henrico, Virginia, 23229", "distance": "10", "id": "1" }, { "address": "113 Buffalo Rd, Clarksville, Virginia(VA), 23927", "distance": "50", "id": "4" }, { "address": "8817 Sherando Dr, Bristow, Virginia(VA), 20136", "distance": "20", "id": "5" }]}';
var params = {
     request: dictstring
gpJSON.execute(params);
import arcpy
import requests
import json
dataInputParameter1 = arcpy.GetParameterAsText(0)
textDict = json.loads(dataInputParameter1)
for employee in textDict['employees']:
    varsearchAddress =  employee["address"]
    varsearchDistance =  employee["distance"]
    varsearchid =  employee["id"]
    print ("address: " + varsearchAddress)
    print ("distance: " + varsearchDistance)
    print ("uniqueid: " + varsearchid)
jaykapalczynski
Honored Contributor
solved
var params = {
     request: dictstring
import arcpy
import requests
import json
jslatane
For anyone else that comes across this and is trying to decipher the code blocks in @jaykapalczynski 's post (I don't know Javascript so take that one for what it's worth):
var params = {request: dictstring};
gpJSON.execute(params);‍‍‍‍‍‍
import arcpy
import requests
import json
    print ("uniqueid: " + varsearchid)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
