How to get database constraint violation error using EditOperation
4877
03-13-2020 07:05 AM
BarbaraSchneider2
I am writing a feature to an Oracle Enterprise Geodatabase using an edit operation:
var editOperation = new EditOperation();
// Assign shape and attributes
var attributes = new Dictionary<string, object>();
attributes.Add(shapeFieldName, shape);
attributes.Add("myField", row["myField"]);
// Create new feature
editOperation.Create(featClass, attributes);
bool succeeded = editOperation.Execute();‍‍‍‍‍‍‍‍‍‍
When executing the editOperation fails, I have no information what went wrong, i.e. if I violated a unique key constraint. Is there a possibilty to get the error? Or is there a better way to write features to an Enterprise Geodatabase?
Thanks, Barbara
by Anonymous User
Not applicable
Hi Barbara,
If the EditOperation fails, the property EditOperation.ErrorMessage may contain the cause if known.
Otherwise you can enable an Oracle TRACE in the database to get detailed information from that side.
by Anonymous User
Not applicable
Hi Barbara,
